Altera_ForumHonored Contributor14 years agoinferring rams with read enable port ? Hi to everyone, I'm trying to infer a tdpram with rden port , because I need the rden port I insert it in the entity and I tried to use the rden signal . I used the VHDL template for tdpram with mixe...Show More
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorConnection bit order between hierarchyCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
