Inferring a True Dual Port RAM with Byte enable for MAX10 FPGA
- 4 years ago
The reason why there are 4 M9K blocks is because of mem_byte0, mem_byte1, mem_byte2 and mem_byte3 you declared.
May go to Edit -> Insert Template -> Verilog HDL -> Full Designs ->RAMs and ROMs and refer to True Dual Port RAM (dual clocks).
May also go to Edit -> Insert Template -> VHDL -> Full Designs ->RAMs and ROMs and refer to Byte-enabled True Dual Port RAM for byte enable. (VHDL)
Sheng
Sheng
- jal_joshi4 years ago
Hi Sheng,
Thanks for your remark. I was able to manage it with a single memory block after referring to the templates.
Jal
