10 years agoInferred RAM: Pass-through logic generated despite no_rw_check
Dear all, I'm a hobbyist currently learning VHDL. My learning vehicle is a self-developed RISC-V CPU that that I develop in the Lite edition of Quartus Prime 15.1. The CPU is working fine alrea...
10 years ago --- Quote Start --- Well, I can always just try my luck ;) Btw, it turns out that in my case the second process is not needed, instead I can have the two read accesses in the same process:
-- this is a pattern that Quartus RAM synthesis understands
-- as *not* being read-during-write (with no_rw_check attribute)
if write_enabled then
regs(to_integer(unsigned(I_selD))) <= data;
else
O_dataS1 <= regs(to_integer(unsigned(I_selS1)));
O_dataS2 <= regs(to_integer(unsigned(I_selS2)));
end if;
What *is* important: There apparently can be only one assignment to the output signals for RAM contents. If one includes, e.g., something like
if I_selS1 = R0 then
O_dataS1 <= X"00000000";
end if;
somewhere (to ensure that reads on CPU register 0 always returns zero) Quartus will include the pass-through logic, no matter if no_rw_check is there or not. Instead I currently live with address 0 actually being a memory location, initializing it with zero and never allowing anything but zero to be written there. --- Quote End --- What would make sense, because the registers in the ram blocks have no mux feeding them. If you code it like this then it has to move the register out of the ram and into general logic. So if you infer a mux, then it becomes an async ram and passthrough would be needed.
