10 years agoInferred RAM: Pass-through logic generated despite no_rw_check
Dear all, I'm a hobbyist currently learning VHDL. My learning vehicle is a self-developed RISC-V CPU that that I develop in the Lite edition of Quartus Prime 15.1. The CPU is working fine alrea...
10 years agoWell, I can always just try my luck ;)
Btw, it turns out that in my case the second process is not needed, instead I can have the two read accesses in the same process:
-- this is a pattern that Quartus RAM synthesis understands
-- as *not* being read-during-write (with no_rw_check attribute)
if write_enabled then
regs(to_integer(unsigned(I_selD))) <= data;
else
O_dataS1 <= regs(to_integer(unsigned(I_selS1)));
O_dataS2 <= regs(to_integer(unsigned(I_selS2)));
end if;
What *is* important: There apparently can be only one assignment to the output signals for RAM contents. If one includes, e.g., something like
if I_selS1 = R0 then
O_dataS1 <= X"00000000";
end if;
somewhere (to ensure that reads on CPU register 0 always returns zero) Quartus will include the pass-through logic, no matter if no_rw_check is there or not. Instead I currently live with address 0 actually being a memory location, initializing it with zero and never allowing anything but zero to be written there.
