10 years agoInferred RAM: Pass-through logic generated despite no_rw_check
Dear all, I'm a hobbyist currently learning VHDL. My learning vehicle is a self-developed RISC-V CPU that that I develop in the Lite edition of Quartus Prime 15.1. The CPU is working fine alrea...
10 years agoThanks to the forum input I was now able to construct a solution that is recognized as not needing pass-through logic:
library IEEE;
use IEEE.std_logic_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
library work;
use work.constants.all;
entity registers is
Port(
I_clk: in std_logic;
I_en: in std_logic;
I_op: in std_logic_vector(1 downto 0);
I_selS1: in std_logic_vector(4 downto 0);
I_selS2: in std_logic_vector(4 downto 0);
I_selD: in std_logic_vector(4 downto 0);
I_dataAlu: in std_logic_vector(XLEN-1 downto 0);
I_dataMem: in std_logic_vector(XLEN-1 downto 0);
O_dataS1: out std_logic_vector(XLEN-1 downto 0);
O_dataS2: out std_logic_vector(XLEN-1 downto 0)
end registers;
architecture Behavioral of registers is
type store_t is array(0 to 31) of std_logic_vector(XLEN-1 downto 0);
signal regs: store_t := (others => X"00000000");
attribute ramstyle : string;
attribute ramstyle of regs : signal is "no_rw_check";
begin
-- first port of dual-port RAM
-- used for one read or one write
process(I_clk)
variable write_enabled: boolean;
variable data: std_logic_vector(XLEN-1 downto 0);
begin
if rising_edge(I_clk) and I_en = '1' then
data := X"00000000";
-- by default assume read access
write_enabled := false;
-- determine details of write operations
case I_op is
when REGOP_WRITE_ALU =>
-- write to destination register
write_enabled := true;
if I_selD /= R0 then
data := I_dataAlu;
end if;
when REGOP_WRITE_MEM =>
data := I_dataMem;
end if;
when others =>
null;
end case;
-- this is a pattern that Quartus RAM synthesis understands
-- as *not* being read-during-write (with no_rw_check attribute)
if write_enabled then
regs(to_integer(unsigned(I_selD))) <= data;
else
O_dataS1 <= regs(to_integer(unsigned(I_selS1)));
end if;
end if;
end process;
-- second port of dual port RAM
-- used only for one read
process(I_clk)
begin
if I_op = REGOP_READ then
O_dataS2 <= regs(to_integer(unsigned(I_selS2)));
end if;
end if;
end process;
end Behavioral;
Will Altera actually process service requests from private individuals? The profile structure of the support pages really has that "we like companies!" vibe ;)
