16 years agoNo that is not possible.
What is possible, and correct, is to write it like this:
always@(posedge CLK) begin : detect_trigger
if (trigger) begin : trigger_active_at_clk_rising_edge
count <= count + 1; // count up
end
end
This produces FPGA friendly code. But it will only work if trigger is active longer than on clk cycle period and less than two clk cycle periods. If you want it to also work when trigger is active for longer periods, than you need to store a auxiliary state variable trigger_d
logic trigger_d;
if (trigger & ~trigger_d) begin : trigger_active_at_clk_rising_edge
count <= count + 1; // count up only at the rising edge of trigger
end
trigger_d <= trigger; // delay it one clk cycle in order to look into the past
end
