16 years agoI added in (posedge trigger) to my code, but it seems not to be working. This is because I only set trigger signal to be high only at certain period. But once I put trigger signal into repeated occurence, just like a CLK, it does give an output with a wrong result.
Can it be possible that I use my posedge CLK as my 1st check list before proceed to check for posedge of my trigger signal? What I mean is that.. I only wan to increment the counter by 1 bit when i pressed trigger signal.. Can it possible to use always statement twice? like always@(posedge CLK) always@(trigger) plz enlight me.. Thanks Regards, Robbie
