Inference of DSP block with accumulator does not work
I use the template below and change the width to 27, and it can fit the accumulator into the hard block. Perhaps, you may try to use the ALTERA_MULT_ADD to configure the accumulator to the mode that you needed.
Please refer to Table 25 for the accumulator function:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/a10_memory.pdf
// Quartus Prime Verilog Template
// Unsigned multiply-accumulate
module unsigned_multiply_accumulate
#(parameter WIDTH=27)
input clk, aclr, clken, sload,
input [WIDTH-1:0] dataa,
input [WIDTH-1:0] datab,
output reg [2*WIDTH-1:0] adder_out
// Declare registers and wires
reg [WIDTH-1:0] dataa_reg, datab_reg;
reg sload_reg;
reg [2*WIDTH-1:0] old_result;
wire [2*WIDTH-1:0] multa;
// Store the results of the operations on the current data
assign multa = dataa_reg * datab_reg;
// Store the value of the accumulation (or clear it)
always @ (adder_out, sload_reg)
begin
if (sload_reg)
old_result <= 0;
else
old_result <= adder_out;
end
// Clear or update data, as appropriate
always @ (posedge clk or posedge aclr)
begin
if (aclr)
begin
dataa_reg <= 0;
datab_reg <= 0;
sload_reg <= 0;
adder_out <= 0;
end
else if (clken)
begin
dataa_reg <= dataa;
datab_reg <= datab;
sload_reg <= sload;
adder_out <= old_result + multa;
end
end
endmodule
