16 years ago --- Quote Start --- Hello all, I am trying to get some sanity with regards to the incremental compilation TCL commands. The first command, PARTITION_HIERARCHY has the following form set_instance_assignment -name PARTITION_HIERARCHY <file name> -to <destination> -section_id <partition name> The field <file name> has no apparent meaning. I see automatically generated commands that will that command filled with something like this. set_instance_assignment -name PARTITION_HIERARCHY uhnwm_b310f9c04033cc46dfd01164df9e352e1 -to "myEnt1:umyEnt1|myEnt2:uMyEnt2" -section_id "myEnt2:uMyEnt2" uhnwm_b310f9c04033cc46dfd01164df9e352e1 appears to be some mess from the database. Ive also seen it with set_instance_assignment -name PARTITION_HIERARCHY root_partition -to | -section_id Top root_partition seems to make a bit more sense, but still is undocumented. The documentation only half way explains whats going on here. Any help is appreciated. --- Quote End --- Hi, can you explain a little more about what you like to know ? How to setup a team-based flow ? Kind regards GPK
