13 years agoThis RTL view bug is intermittent - I can see the inversion on your picture. But if you set RTL viewer options to uncheck "Group all related nodes", then inversion disappears. And when you check "Group all related nodes" again, then .... you will get the schematics view without inversion. So, this is some bug in RTL visualisation.
I have a related question - is there some way to get the RTL view in an ASCII form, i.e. just the netlist? The way Quartus draws schematics is far from perfect and I would rather move elements manually using some other schematic entry tool.
