10 years ago
Inconsistency detected by ld.so: dl-close.c: 764: _dl_close: Assertion `map->l_init_c
I keep getting this message whenever I run Quartus (15.0) on most non-supported Linux distributions. The message does not seem to be fatal, but some tools/scripts will check the output of Quartus and fail whenever the above error is written to stdout.
According to https://www.altera.com/support/support-resources/knowledge-base/solutions/rd01272015_37.html this should (or maybe that was a fatal version?) have been fixed in 15.0.
Any ideas to get around the problem or if it will it be fixed in 15.1?
    I had same problem.
    wbgreen's solution seemed to be correct answer. but, it didn't work.
    so, I restored .bak files one by one except 'libccl_curl_drl.so.bak'
    I don't know why, Quartus Prime goes well. Anyone knows about this?
