15 years agoIncircuit Programming Issues
Using Quartus II v. 9.1 SP1, and a USB blaster, Rev.C, I currently have
two boards that experience the same issue. I can connect to the JTAG port on my design and successfully aquire the three CPLD's in the JTAG chain with the programmer, however, when I try to program the chain, I get the following error: Error: JTAG ID code specified in JEDEC STAPL Format File does not match any valid JTAG ID codes for device. One of these board actually has successfully been programmed several times before, but after changing one of the CPLD's has started this problem. I have other boards of this same design that program correctly every time. The three CPLD's in the Jtag chain are an EPM7032SL44-10, and two EPM7128SLC84's. All of these IC's have been purchased recently from Digi-Key. Any help would be appreciated Thanks
