11 years ago#in Verilog
HI, I have a question what is# 1 in the command here. Is it just a comment. Sorry, im a newbie in verilog.
module simple_counter (
CLOCK_50,
counter_out
input CLOCK_50 ;
output counter_out;
reg counter_out;
always @ (posedge CLOCK_50) // on positive clock edge
begin
counter_out <=# 1 counter_out + 1;// increment counter
end
endmodule // end of module counter
CLOCK_50,
counter_out
input CLOCK_50 ;
output counter_out;
reg counter_out;
begin
counter_out <= #1 counter_out + 1;// increment counter
end
Thanks, i will learn and grab it. Really appreciate so much.!!
--- Quote Start --- HI, I have a question what is# 1 in the command here. Is it just a comment. Sorry, im a newbie in verilog.
--- Quote End --- # 1 indicates that the output "counter_out" is delayed by 1 time unit after the rising edge of the clock. The units (ns, ps, etc.) are defined by a separate `timescale statement or the system verilog command "timeunit." At any rate, it's not shown in your code. I've come across many designers in my career who put a delay in every single line of their synthesizable code so it looks more realistic in the simulator. I do NOT recommend this, as this will affect the simulator speed. And quite frankly, it's a nuisance to type. In addition, these delays are ignored by synthesis tools, and many of them will print out a warning that the delay was ignored for every statement. However, delays such as these are very useful and necessary in testbenches. Robert lead VHDL/Verilog trainer www.digitaldesignconcepts.org (http://www.digitaldesignconcepts.org)module simple_counter ( CLOCK_50, counter_out ); input CLOCK_50 ; output counter_out; reg counter_out; always @ (posedge CLOCK_50) // on positive clock edge begin counter_out <=# 1 counter_out + 1;// increment counter end endmodule // end of module counter module simple_counter ( CLOCK_50, counter_out ); input CLOCK_50 ; output counter_out; reg counter_out; always @ (posedge CLOCK_50) // on positive clock edge begin counter_out <= #1 counter_out + 1;// increment counter end endmodule // end of module counter
