18 years agoHello,
I thought it could be that the in-system memory content editor window shows outdated info, as it could happen with source&probe tool. But I saw, that when you perform a scan chain, you get always an updated display of all existing memory instances, respectively No Instances Found. So I think the only way to see outdated instance info is that the most recent compilation result wasn't loaded to FPGA. This could happen e. g. if you once selected a different *.sof file in JTAG Chain Confuguration or the JTAG configuration was overwritten from a different configuration source also in effect. Regards, Frank
