18 years agoHello,
regularly, the editor shows all existing instances, when you scan the device. You can select one at a time to communicate with. You should first check in compilation report if both instances actually have been created. The memory instances must have an unique numeric instance ID in addition to the displayed name, but with default settings it is choosen automaticly. You can see this also from the report. Regards, Frank
