AMoralesv
6 years agoIn old Quartus 9.1, I was able to overwrite input vwf file with simulation output (timing and functional). Also, I was able to see internal state of FSM machines in design (not connected to output pins). How can I do the same in Quartus Prime 18.1?
In Quartus Prime 18.1, even though I add the state machine (in the example that follows, is called "actual") in input Waveform.vwf, the simulation output does not show any value change in the state o...
Vicky1
6 years agoHi,
It may not be available in vector waveform file but you can see it in ModelSim simulation.
Vicky
