AMoralesv
6 years agoIn old Quartus 9.1, I was able to overwrite input vwf file with simulation output (timing and functional). Also, I was able to see internal state of FSM machines in design (not connected to output pins). How can I do the same in Quartus Prime 18.1?
In Quartus Prime 18.1, even though I add the state machine (in the example that follows, is called "actual") in input Waveform.vwf, the simulation output does not show any value change in the state o...
AMoralesv
6 years agoDear Vicky,
Here is the input waveform. Device selected: Cyclone IV E EP4CE6E22C6
You can see that I inserted the internal signal "actual", following Insert --> Node or Bus, the I pressed "Node Finder..", and then I filtered by "Design Entry (all names).
The selected signal is type "State Machine"
In the next message, you will see the output waveform.
