万江
7 years agoIn A10/C10 hard ip for PCIe, size of address pages can't be 128KB to 2MB
Hello, I'm testing PCIe on a C10 devkit by quartus 18.0pro. Application interface type = Avalon_MM(no DMA), Avalon_MM address width = 32bits. Under Avalon-MM settings tab, why size of address pag...
万江
7 years agoHi Nathan,
Thank you very much.
Now I still not clear how high PCIe address bits are determined, when Address width of accessible PCIe memory space is LESS than 64.
My solution is:
set AVMM address width = 64, and set Address width of accessible PCIe memory space = 64
writing a dedicated component to master txs point-to-point, it controls all 64 address bits of txs.
at the same time, the component is an MM slave too. the host will tell it where the dma buffer is thru a BAR.
the txs can NOT be connected to the main QSYS directly, because it will occupy ALL address space.
it does work, but it looks a little stupid.
Jiang Wanli
