15 years agoAlthough my initial clock rate is 200MHz, I would like to increase the speed up to 400MHz clock, thus 800Mbits data. My serialiser thus needs to be /2. You are right that when it goes to /4 the phase option appears.
One other thing I did was to cut the data bus down to 1 bit. I gained 50ps (at 400MHz clock) of data window but the ODV did not move. I didn't really expect it to move though :(. Thanks for your continued help Rysc C
