wayne's avatar
wayne
6 years ago
Import tcl-script to Quartus
After creating the list of modifications in the ECO file using Change Manager in Chip Planner, I exported the modifications as a tcl file.
But I can’t import this file into the project. After starting it through the TCL sripts built-in utility, an error appears on the command line:
<Error: ERROR: Unable to find Chip Planner netlist. Read the netlist by using the "read_netlist" command.>
Inside the tcl file, the read_netlist command is executed. And of course I am doing a full compilation of the project before this
  • wayne's avatar
    wayne
    Then you need to do a series of actions, which I described in my message with screenshot. When changing the structure of one of the area, you will get a fitter error
  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    I checked the cells in Region_0 and Region_1; all of them are in Arithmetic operation mode. May I know in which module you modify the cell?
  • wayne's avatar
    wayne
    For example, the problem occurs after deleting the last cell in region 0, and the first cell in region 1. I want to connect them directly through carry chain. I guess the problem is not with LogicLock itself, but with the principles of the LE structure.
    KhaiChein_Y_Intel
    Can you share how do you perform the below changes steps by steps in details including the cell name, signal name and node name?
    I need each adder to be connected via Cin / Cout carry chains and not through Combout / DataABCD.
    As a result of the corrections in the Resource Property Editor, I delete the LEs that work in normal mode and connect each LAB through the carry chains.
  • wayne's avatar
    wayne
    1) I delete the last LE from Region0 "result_int[15]~30"
    2) I delete the first LE from Region1 "result_int[0]~1"
    3) I connect the COUT of the penultimate LE from Region0 "result_int[14]~29" to the CIN of the second LE from Region1 "result_int[1]~3"
    As a result, I want to get two adders connected only by a carry chain
    To do the above operations, you can run the updated script.
    KhaiChein_Y_Intel
    Yes. You are correct. The logic lock region assignments are removed when the nodes in a carry chain assigned to a logic lock region is assigned to some of the nodes in a carry chain in another location. To place the carry chain correctly, the Fitter removed the Logic Lock region assignments on the nodes in the carry chain.
