wayne
7 years agoImport tcl-script to Quartus
After creating the list of modifications in the ECO file using Change Manager in Chip Planner, I exported the modifications as a tcl file. But I can’t import this file into the project. After start...
wayne
6 years agoHi,
1) I delete the last LE from Region0 "result_int[15]~30"
2) I delete the first LE from Region1 "result_int[0]~1"
3) I connect the COUT of the penultimate LE from Region0 "result_int[14]~29" to the CIN of the second LE from Region1 "result_int[1]~3"
As a result, I want to get two adders connected only by a carry chain
To do the above operations, you can run the updated script.
