Import Package error System Verilog
I have a few packages that I have written like this:
package A;
endpackage
package B;
import A::*
endpackage
package C;
import A::*;
import B::*;
endpackage
In the file using package C, the error I am getting is as follows:
Error (10864): SystemVerilog error at C.sv(26): TMP was imported from multiple packages with ::* - none of the imported declarations are visible.
Is this problem because I am importing A::* in both package A and package C?
Any help to rsolve this is greatly appreciated.
Thanks in Advance~
Nikhil Pratap
- Vicky1
"Is this problem because I am importing A::* in both package A and package C?"
Yes, Please refer the below attached doc from Language reference manual(LRM) especially
"Table 26-1—Scoping rules for package importation" & Examples under the "26.6 Exporting imported names from packages"
Best Regards
Vikas Jathar
- dave_59
It would help if you showed the places where TMP was declared and referenced. The import A::* by itself is not the problem. Most likely because you have declared TMP in both packages A and B and tried to reference it in C.
