17 years ago
Import of sdc
I'm new here and still studying Quartus. I currently have a module and also have an SDC file for its constraints.
Is it possible to import an existing project and it's SDC as a submodule of a new project?
Do I need to change the SDC (specially those constraints accessing collections of ports) since the design will now be a module in the project?
I have heard about bottom-up flow, will this apply?
regards,
Edzel
    --- Quote Start ---
    regards,
    Edzel
    --- Quote End ---
    Hi Edzel,
    as far as I know you can use only one SDC file in a Quartus project. In case that the ports of the submodule are toplevel ports also you can reuse your SDC settings otherwise you can skip it.
    Kind regards
    GPK
    You can add multiple SDC files to the project. You can also add a line to your main SDC file to "source" other SDC files if you'd prefer to do it that way. So just compile the component into your design like you normally would and add the SDC file to the list of SDC files for the project.
    Jake
