12 years ago --- Quote Start --- It is all verilog, but the theory is the same (and reading verilog would be more up your street if you're a programmer) Also study the coding guidelines in the quartus manual. Lots of code examples and templates in there. --- Quote End --- For what it's worth, this is the behavioral model of what I'm trying to do (I've got a block diagram below if it's easier to follow): --- Quote Start --- architecture behavioral of bounce_processor is signal tempQ: std_logic;signal lastIntervalValue: std_logic_vector(4 downto 0); begin process(clock, clr) begin tempQ <= d; lastIntervalValue <= interval; if(clr = '1') then q <= '0'; elsif (rising_edge(clock) and start = '1') then if opcode = "000" then q <= '0'; elsif opcode = "001" then --initial bounce pulse when kicked off
q <= not tempq;
tempq <= not tempq;
while (interval > "00000") loop
-- complement pulse only when interval value changes
if (interval /= lastintervalvalue) then
q <= not tempq;
tempq <= not tempq;
lastintervalvalue <= interval;
end if;
end loop;
-- ensure final output is a complent of d regardless of pulses
q <= not d;
elsif opcode = "010" then q <= '1'; elsif opcode = "011" then q <= '0'; end if; end if; end process; end behavioral; --- Quote End --- https://www.alteraforum.com/forum/attachment.php?attachmentid=7394
