9 years agoImplement mux using for loop
Hi I think it is possible to implement a mux using a for loop like in the following example:
type array_type is array (7 downto 0) of std_logic_vector(15 downto 0);
signal mux_in: array...
9 years agoWhen building (having just tried it) it fills the non-existing entries with 0's without modifying my code (other than the array size)
In simulation, it would throw an error. This is probably the best situation, as you wouldnt want control logic selecting a non-existing connection. code I synthed:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
package test_pkg is
type array_type is array (5 downto 0) of std_logic_vector(15 downto 0);
end package test_pkg;
library ieee;
use work.test_pkg.all;
entity mux_test is
port (
mux_in : in array_type;
mux_slct : in unsigned(2 downto 0);
mux_out : out std_logic_vector(15 downto 0)
end entity mux_test;
architecture rtl of mux_test is
begin
mux_out <= mux_in( to_integer( mux_slct) );
end architecture rtl;
Synthed with Quartus Lite 17
