- Vicky1
I tried to recreate the issue you faced but I haven`t come across any warning.
Can you provide your full code?
Best Regards
Vikas Jathar
- Abe
Well, this can happen depending on the value thats stored in the AXIMISC signal/register. Since you're adding two 32-bit values, there could be an overflow in the result and this is what the synthesis tool is truncating away to fit into the resultant register.
I would suggest checking the bus/bit-widths of the variables/signals in question as well as the final result of the addition to see if there is any overflow.
- CosmoKramer
I am having similar warning. If I am confident that there is no possibility of an overflow, how can I prevent truncation?
If there was an overflow then should it not result in 33 bits instead of 34 bits?
