You're right Tricky. I confused inferred latch with another concept. When you ommitted a signal in sensitivy list, like:
process(a)
begin
c <= a or b;
end process;
It seems like we're trying to describe some kind of inferred memory because a change on b not change the output. This was I was thinking.
As you said, Quaryus implement latches. I saw a technoloy map viewer and there are a subtle difference in how Quartus understand the code:
process(le, d)
begin
if( le = '1' ) then
q <= d;
end if;
end process;
This version inferred a latch.
With this:
process(le)
begin
if( le = '1' ) then
q <= d;
end if;
end process;
inferred a flip-flop d without usign 'event clause.
