ibis_writer.py "Execution has failed. Reason is: Parasitic file not found."
Trying to generate an IBIS model for my implementation using the 23.1 instructions and ibis_writer.py script and I get:
"Error occured. Look in the error log file ibis_writer.log for more details"
There is no ibis_writer.log that I can find. so Any help please?
Based on the user guide https://www.intel.com/content/www/us/en/docs/programmable/683768/23-1/ibis-model-access-and-customization-flows.html, it mentioned that the generation of IBIS model for Agilex 7 is not supported. You need to install/download the IBIS models provided in https://www.intel.com/content/www/us/en/support/programmable/support-resources/board-layout/ibs-ibis-index.html.
Aqid
- AqidAyman_Altera
Hi Brian,
Can you share with me the procedure you used to generate the IBIS model or the instructions you followed?
Also, what device is this?
Aqid
- brian1211
Followed the instructions in $QUARTUS_INSTALL_DIR/common/misc/ibis_writer/README.txt
quartus_cdb -t /<absolute_path>/intel_type3_cxl_ip_0_ed/hardware_test_design/ibis/dump_atom_netlist.tcl -project /<absolute_path>/intel_type3_cxl_ip_0_ed/hardware_test_design/cxltyp3_memexp_ddr4_top.qpf
$QUARTUS_INSTALL_DIR/common/misc/ibis_writer/ibis_writer.py --mutual_inductance true --pin_file /<absolute_path>/intel_type3_cxl_ip_0_ed/hardware_test_design/output_files/cxltyp3_memexp_ddr4_top.pin --atom_file /<absolute_path>/intel_type3_cxl_ip_0_ed/hardware_test_design/atom_netlist.json /<absolute_path>/intel_type3_cxl_ip_0_ed/hardware_test_design/output_files/cxltyp3_memexp_ddr4_top.ibs
Device is: AGIB027R29A1E2VR3
- AqidAyman_Altera
Aqid
- AqidAyman_Altera
As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
