brian1211
3 years agoibis_writer.py "Execution has failed. Reason is: Parasitic file not found."
Trying to generate an IBIS model for my implementation using the 23.1 instructions and ibis_writer.py script and I get: "Execution has failed. Reason is: Parasitic file not found." "Error occured. ...
- 3 years ago
Based on the user guide https://www.intel.com/content/www/us/en/docs/programmable/683768/23-1/ibis-model-access-and-customization-flows.html, it mentioned that the generation of IBIS model for Agilex 7 is not supported. You need to install/download the IBIS models provided in https://www.intel.com/content/www/us/en/support/programmable/support-resources/board-layout/ibs-ibis-index.html.
Aqid
AqidAyman_Altera
3 years agoHi Brian,
Can you share with me the procedure you used to generate the IBIS model or the instructions you followed?
Also, what device is this?
Aqid
