12 years ago
I2C Help!
I am new to VHDL. I am trying to write the I2C protocol to store the value '10101010' in EEPROM on my DE0 Nano board.
Would anyone please help me as to show where I am going wrong? I am getting compilation errors saying "can't resolve multiple constant drivers for net "I2C_SCLK" " etc.
Thanks alot in advance
Library IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
use ieee.numeric_std.all;
ENTITY i2c IS
PORT (  clock_50 : IN STD_LOGIC;
		  LED : OUT STD_LOGIC_VECTOR( 7 DOWNTO 0 );
		  Key : IN STD_LOGIC_VECTOR ( 1 DOWNTO 0);
		  I2C_SCLK : OUT STD_LOGIC;
		  I2C_SDAT : INOUT STD_LOGIC:= '1'
END i2c;
ARCHITECTURE behaviour OF i2c IS
SIGNAL GO  : STD_LOGIC:= '0';
SIGNAL ref_clk  : STD_LOGIC;
SIGNAL SDI : STD_LOGIC;
SIGNAL SCLK: STD_LOGIC;
SIGNAL SD_COUNTER : INTEGER := 0;
SIGNAL COUNT : INTEGER := 0;
BEGIN
I2C_SCLK<= NOT (ref_clk) WHEN (SD_COUNTER >=4 AND SD_COUNTER <= 32);
PROCESS (clock_50)
BEGIN
	IF (clock_50'event AND clock_50 = '1') THEN
		COUNT<= COUNT + 1;
	END IF;
	IF (COUNT >= 512) THEN
		COUNT<=0;
		ref_clk<= NOT(ref_clk);
	END IF;
END PROCESS;
PROCESS (key)
BEGIN
	IF(key(0) = '0') THEN
		GO <= '0';
	END IF;
	IF(key(1) = '0') THEN
		GO <= '1';
		I2C_SCLK <= '1';
		I2C_SDAT <= '1';
	END IF;
END PROCESS;
PROCESS (ref_clk)
BEGIN
	IF ( (ref_clk'EVENT AND ref_clk = '1') AND SD_COUNTER < 34 AND GO = '1') THEN
			SD_COUNTER<= SD_COUNTER + 1;
		CASE SD_COUNTER IS
			WHEN  1  =>
				I2C_SCLK <= '1';
				I2C_SDAT <= '1';
			WHEN  2  =>
				I2C_SDAT <= '0';
			WHEN  3  =>
				I2C_SCLK <= '0';
			--Slave Addr
			WHEN  4  =>
				I2C_SDAT <= '1';
			WHEN  5  =>
				I2C_SDAT <= '0';
			WHEN  6  =>
				I2C_SDAT <= '1';
			WHEN  7  =>
				I2C_SDAT <= '0';
			WHEN  8  =>
				I2C_SDAT <= '0';
			WHEN  9  =>
				I2C_SDAT <= '0';
			WHEN  10  =>
				I2C_SDAT <= '0';
			WHEN  11  =>
				I2C_SDAT <= '0';
			WHEN  12  =>
				I2C_SDAT <= 'Z';
			--Reg Addr
			WHEN  13  =>
				I2C_SDAT <= '0';
			WHEN  14  =>
				I2C_SDAT <= '0';
			WHEN  15  =>
				I2C_SDAT <= '0';
			WHEN  16  =>
				I2C_SDAT <= '0';
			WHEN  17  =>
				I2C_SDAT <= '0';
			WHEN  18  =>
				I2C_SDAT <= '0';
			WHEN  19  =>
				I2C_SDAT <= '0';
			WHEN  20  =>
				I2C_SDAT <= '0';
			WHEN  21  =>
				I2C_SDAT <= 'Z';
			--Data
			WHEN  22  =>
				I2C_SDAT <= '1';
			WHEN  23  =>
				I2C_SDAT <= '0';
			WHEN  24  =>
				I2C_SDAT <= '1';
			WHEN  25  =>
				I2C_SDAT <= '0';
			WHEN  26  =>
				I2C_SDAT <= '1';
			WHEN  27  =>
				I2C_SDAT <= '0';
			WHEN  28  =>
				I2C_SDAT <= '1';
			WHEN  29  =>
				I2C_SDAT <= '0';
			WHEN  30  =>
				I2C_SDAT <= 'Z';
			WHEN  31  =>
				I2C_SCLK <= '1';
				I2C_SDAT <= '1';
			WHEN  32  =>
				I2C_SDAT <= 'Z';
				GO <= '0';
			WHEN OTHERS =>
				I2C_SDAT <= 'X';
		END CASE;
	END IF;
END PROCESS;
END behaviour;
    in your PROCESS(KEY) and PROCESS(reg_clk) both processes are writing to I2C_SCLK. Thats a big no no in VHDL.
    --- Quote Start ---
    --- Quote End ---
    I removed the writing to I2_SCLK in PROCESS(KEY) but still get an error because of the assignment to I2C_SCLK in "I2C_SCLK<= NOT (ref_clk) WHEN (SD_COUNTER >=4 AND SD_COUNTER <= 32);" as PROCESS(reg_clk) is also writing to it.
    How would you suggest a better way to do this? I wish to assign ref_clock to I2C_SCLK only when SD_COUNTER >= 4 and <= 32? Many thanks.
    yes, since the line
    and both PROCESS(reg_clk) is modifying I2C_SCLK you'll still get the error.
    if you really only "wish to assign ref_clock to I2C_SCLK only when SD_COUNTER >= 4 and <= 32" then remove all modifications of I2C_SCLK <= from PROCESS(reg_clk) or remove the line I2C_SCLK<= NOT (ref_clk) WHEN (SD_COUNTER >=4 AND SD_COUNTER <= 32); I dont think you can just have a statement that uses when without putting it into a process.
    so,
    I'd suggest you use a state machine
    off the top of my head, without looking into detail as to what your overall goal is something like this may work:
    Library IEEE;
    ENTITY i2c IS
    END i2c;
    type state is
        IN_RANGE, NOT_IN_RANGE
    signal Status : state;
    BEGIN
    process (clock_50)
        begin
            if (clock_50'event AND clock_50 = '1') then
                case Status is
                    when IN_RANGE =>
                        I2C_SCLK<= NOT (ref_clk);
                        if NOT(SD_COUNTER >=4 AND SD_COUNTER <= 32) then
                            Status <= NOT_IN_RANGE;
                        end if;
                    when NOT_IN_RANGE =>
                        I2C_SCLK<=(ref_clk);
                        if (SD_COUNTER >=4 AND SD_COUNTER <= 32) then
                            Status <= IN_RANGE;
                        end if;
                end case;
            end if;
    end process;
    PROCESS (clock_50)
    BEGIN
            COUNT<= COUNT + 1;
        END IF;
            COUNT<=0;
        END IF;
    END PROCESS;
    PROCESS (key)
    BEGIN
            GO <= '0';
        END IF;
            GO <= '1';
            I2C_SDAT <= '1';
        END IF;
    END PROCESS;
    PROCESS (ref_clk)
    BEGIN
            CASE SD_COUNTER IS
                WHEN  1  =>
                    I2C_SDAT <= '1';
                WHEN  2  =>
                    I2C_SDAT <= '0';
                WHEN  3  =>
                    I2C_SDAT <= '0';
                --Slave Addr
                WHEN  4  =>
                    I2C_SDAT <= '1';
                WHEN  5  =>
                    I2C_SDAT <= '0';
                WHEN  6  =>
                    I2C_SDAT <= '1';
                WHEN  7  =>
                    I2C_SDAT <= '0';
                WHEN  8  =>
                    I2C_SDAT <= '0';
                WHEN  9  =>
                    I2C_SDAT <= '0';
                WHEN  10  =>
                    I2C_SDAT <= '0';
                WHEN  11  =>
                    I2C_SDAT <= '0';
                WHEN  12  =>
                    I2C_SDAT <= 'Z';
                --Reg Addr
                WHEN  13  =>
                    I2C_SDAT <= '0';
                WHEN  14  =>
                    I2C_SDAT <= '0';
                WHEN  15  =>
                    I2C_SDAT <= '0';
                WHEN  16  =>
                    I2C_SDAT <= '0';
                WHEN  17  =>
                    I2C_SDAT <= '0';
                WHEN  18  =>
                    I2C_SDAT <= '0';
                WHEN  19  =>
                    I2C_SDAT <= '0';
                WHEN  20  =>
                    I2C_SDAT <= '0';
                WHEN  21  =>
                    I2C_SDAT <= 'Z';
                --Data
                WHEN  22  =>
                    I2C_SDAT <= '1';
                WHEN  23  =>
                    I2C_SDAT <= '0';
                WHEN  24  =>
                    I2C_SDAT <= '1';
                WHEN  25  =>
                    I2C_SDAT <= '0';
                WHEN  26  =>
                    I2C_SDAT <= '1';
                WHEN  27  =>
                    I2C_SDAT <= '0';
                WHEN  28  =>
                    I2C_SDAT <= '1';
                WHEN  29  =>
                    I2C_SDAT <= '0';
                WHEN  30  =>
                    I2C_SDAT <= 'Z';
                WHEN  31  =>
                    I2C_SDAT <= '1';
                WHEN  32  =>
                    I2C_SDAT <= 'Z';
                    GO <= '0';
                WHEN OTHERS =>
                    I2C_SDAT <= 'X';
            END CASE;
        END IF;
    END PROCESS;
    END behaviour;
