yes, since the line
"I2C_SCLK<= NOT (ref_clk) WHEN (SD_COUNTER >=4 AND SD_COUNTER <= 32);"
and both PROCESS(reg_clk) is modifying I2C_SCLK you'll still get the error.
if you really only "wish to assign ref_clock to I2C_SCLK only when SD_COUNTER >= 4 and <= 32" then remove all modifications of I2C_SCLK <= from PROCESS(reg_clk) or remove the line I2C_SCLK<= NOT (ref_clk) WHEN (SD_COUNTER >=4 AND SD_COUNTER <= 32); I dont think you can just have a statement that uses when without putting it into a process.
so,
I'd suggest you use a state machine
off the top of my head, without looking into detail as to what your overall goal is something like this may work:
Library IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
use ieee.numeric_std.all;
ENTITY i2c IS
PORT ( clock_50 : IN STD_LOGIC;
LED : OUT STD_LOGIC_VECTOR( 7 DOWNTO 0 );
Key : IN STD_LOGIC_VECTOR ( 1 DOWNTO 0);
I2C_SCLK : OUT STD_LOGIC;
I2C_SDAT : INOUT STD_LOGIC:= '1'
END i2c;
ARCHITECTURE behaviour OF i2c IS
SIGNAL GO : STD_LOGIC:= '0';
SIGNAL ref_clk : STD_LOGIC;
SIGNAL SDI : STD_LOGIC;
SIGNAL SCLK: STD_LOGIC;
SIGNAL SD_COUNTER : INTEGER := 0;
SIGNAL COUNT : INTEGER := 0;
type state is
IN_RANGE, NOT_IN_RANGE
signal Status : state;
BEGIN
process (clock_50)
begin
if (clock_50'event AND clock_50 = '1') then
case Status is
when IN_RANGE =>
I2C_SCLK<= NOT (ref_clk);
if NOT(SD_COUNTER >=4 AND SD_COUNTER <= 32) then
Status <= NOT_IN_RANGE;
end if;
when NOT_IN_RANGE =>
I2C_SCLK<=(ref_clk);
if (SD_COUNTER >=4 AND SD_COUNTER <= 32) then
Status <= IN_RANGE;
end if;
end case;
end if;
end process;
PROCESS (clock_50)
BEGIN
IF (clock_50'event AND clock_50 = '1') THEN
COUNT<= COUNT + 1;
END IF;
IF (COUNT >= 512) THEN
COUNT<=0;
ref_clk<= NOT(ref_clk);
END IF;
END PROCESS;
PROCESS (key)
BEGIN
IF(key(0) = '0') THEN
GO <= '0';
END IF;
IF(key(1) = '0') THEN
GO <= '1';
I2C_SDAT <= '1';
END IF;
END PROCESS;
PROCESS (ref_clk)
BEGIN
IF ( (ref_clk'EVENT AND ref_clk = '1') AND SD_COUNTER < 34 AND GO = '1') THEN
SD_COUNTER<= SD_COUNTER + 1;
CASE SD_COUNTER IS
WHEN 1 =>
I2C_SDAT <= '1';
WHEN 2 =>
I2C_SDAT <= '0';
WHEN 3 =>
I2C_SDAT <= '0';
--Slave Addr
WHEN 4 =>
I2C_SDAT <= '1';
WHEN 5 =>
I2C_SDAT <= '0';
WHEN 6 =>
I2C_SDAT <= '1';
WHEN 7 =>
I2C_SDAT <= '0';
WHEN 8 =>
I2C_SDAT <= '0';
WHEN 9 =>
I2C_SDAT <= '0';
WHEN 10 =>
I2C_SDAT <= '0';
WHEN 11 =>
I2C_SDAT <= '0';
WHEN 12 =>
I2C_SDAT <= 'Z';
--Reg Addr
WHEN 13 =>
I2C_SDAT <= '0';
WHEN 14 =>
I2C_SDAT <= '0';
WHEN 15 =>
I2C_SDAT <= '0';
WHEN 16 =>
I2C_SDAT <= '0';
WHEN 17 =>
I2C_SDAT <= '0';
WHEN 18 =>
I2C_SDAT <= '0';
WHEN 19 =>
I2C_SDAT <= '0';
WHEN 20 =>
I2C_SDAT <= '0';
WHEN 21 =>
I2C_SDAT <= 'Z';
--Data
WHEN 22 =>
I2C_SDAT <= '1';
WHEN 23 =>
I2C_SDAT <= '0';
WHEN 24 =>
I2C_SDAT <= '1';
WHEN 25 =>
I2C_SDAT <= '0';
WHEN 26 =>
I2C_SDAT <= '1';
WHEN 27 =>
I2C_SDAT <= '0';
WHEN 28 =>
I2C_SDAT <= '1';
WHEN 29 =>
I2C_SDAT <= '0';
WHEN 30 =>
I2C_SDAT <= 'Z';
WHEN 31 =>
I2C_SDAT <= '1';
WHEN 32 =>
I2C_SDAT <= 'Z';
GO <= '0';
WHEN OTHERS =>
I2C_SDAT <= 'X';
END CASE;
END IF;
END PROCESS;
END behaviour;
