SBurk3
7 years agoI keep getting this error when i try and compile and havent been able to solve it. Any suggestions?
Error (12006): Node instance "inst" instantiates undefined entity "Lab_9_SevSegV2". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
- CalvinJoaz_P_Intel
Contributor
Hi Sean Burke, Good day. You are getting this error because you didn't set your own library, yet. Go to assignment -> Settings -> Library (Category Field) -> Add your library path, then apply it. Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Thank you.- SBurk3
Yes it did thank you so much I have been stuck on this for hours your a life saver
- Fredeico
- sstrell
Really should create a new post, but without seeing the code where these instantiations are done, it's hard to tell what's wrong. Assuming you have divisor.vhd and PWM.vhd in that library location.
