SBurk3
7 years agoI keep getting this error when i try and compile and havent been able to solve it. Any suggestions?
Error (12006): Node instance "inst" instantiates undefined entity "Lab_9_SevSegV2". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiati...
Fredeico
2 years agoHi all.
I'm having the same issue.
I tried to set the library, but the error persists.
The difference is I'm writing VHDL code.
Any ideas?
sstrell
2 years agoReally should create a new post, but without seeing the code where these instantiations are done, it's hard to tell what's wrong. Assuming you have divisor.vhd and PWM.vhd in that library location.
