eng_jp
3 years agoI earn different implement result between linux and windows
Hi
Does Quartus not earn same result between Linux version and Windows version?
I tried following conditions:
1. Quartus 18.1 standard edition.
2. set same compile option.
3. start compi...
- 3 years ago
Hi, Sheng
OK, this topic is solved.
Thank you for your works.
ShengN_altera
3 years agoHi,
I don't think there will be different results between Linux version and Windows version because both versions theoretically have the same compilation engine. Could you provide the project for testing out?
Sheng
- eng_jp3 years ago
Hi, Sheng
Thank you for quick reply.
I found Intel's official comment as below:
3.1.1.1. Factors Affecting Compilation Results (intel.com)
I think this comment might old information. Is it effective comment on Quartus18.1?
or as you say, compile result should be same?
best regards,
