I am using Intel IP components. I used quartus to create the ModelSim script to compile the design. When ModelSim attempts to start simulation, I get Errors for all the Intel IP as shown in the details section.
# ** Error: (vsim-3935) C:/Projects/A10_BSM/BSM_EPL_PCL_EGL/simulation/modelsim/../../new_ip/CCP_RAM/sim/CCP_RAM.vhd(45): Port 'A_IN' not found in the connected module.
# Time: 0 ps Iteration: 0 Instance: /bsm_epl_pcl_egl_bsf_tst/uut/b2v_inst45/b2v_inst3/b2v_inst136/ram_1port_0 File: C:/Projects/A10_BSM/BSM_EPL_PCL_EGL/simulation/modelsim/../../new_ip/CCP_RAM/ram_1port_180/sim/CCP_RAM_ram_1port_180_iletabi.v
- CHatz
Adding the libraries in the top level file, eliminates the Errors:
--edits for simulation
library altera_mf;
use altera_mf.all;
library altera;
use altera.all;
- AnandRaj_S_Intel
Can you share more information On IP used & its Configuration, Quartus and modelsim tools version used in your design process?
Are you trying to simulate single IP or complete design?
Share transcript of modelsim.
Make sure appropriate version of Quartus tools and modelsim are used.
Example if you use Quartus 18.0 you need to use modelsim 10.6c if Quartus 17.0 use modelsim 10.5b.
Anand Raj Shankar
- CHatz
Hello Anand,
I am using the Quartus 18.0 package. This package came with the ModelSim 10.5b version and that's the version I am using to
simulate.
I am simulating a complete design containing Intel IP and custom components.
Unfortunately, the Intel Web Site won't allow me to upload the files.
Costas Hatzinikolaou,
Sperry Rail Corporation.
