CHatz
7 years agoI am using Intel IP components. I used quartus to create the ModelSim script to compile the design. When ModelSim attempts to start simulation, I get Errors for all the Intel IP as shown in the details section.
# ** Error: (vsim-3935) C:/Projects/A10_BSM/BSM_EPL_PCL_EGL/simulation/modelsim/../../new_ip/CCP_RAM/sim/CCP_RAM.vhd(45): Port 'A_IN' not found in the connected module. # Time: 0 ps Iteration: 0 In...
AnandRaj_S_Intel
7 years agoHi,
Can you share more information On IP used & its Configuration, Quartus and modelsim tools version used in your design process?
Are you trying to simulate single IP or complete design?
Share transcript of modelsim.
Make sure appropriate version of Quartus tools and modelsim are used.
Example if you use Quartus 18.0 you need to use modelsim 10.6c if Quartus 17.0 use modelsim 10.5b.
Anand Raj Shankar
