12 years ago
I am having to re-assign the default pin, in Quartus II v 13.0sp1
I have been using Quartus for many years, and have not seen this problem before - what am I doing wrong ? :
I have a top-level .bdf block diagram, that contains a .bdf with output that is linked directly to an output pin :
https://www.alteraforum.com/forum/attachment.php?attachmentid=7604
It shows IOC[3] linked to the correct FPGA pin, E3, as defined in the device assignment table.
When I compile, IOC[3] is left disconnected, a new pin IOC3 is created, and assigned to a FPGA pin that is not connected on the board.
If I use pin-swap, I can reassign IOC3 to FPGA pin E3.
I have also tried using pin name IOC3.
What is going on ? Am I omitting some necessary set-up information ?
The diagram is an existing one that already contains a number of input and output pins assigned in the same way, with no such problems.
cheers,
Dr. Beau Webber
    OK, it seems that my pin assignments are being ignored :
    Warning (171167): Found invalid Fitter assignments. See the Ignored Assignments panel in the Fitter Compilation Report for more information.
    The assignments I am using have been copied from MorphIO-II Rev1.2, which re-compiles and runs fine.
    Any ideas as to why they are being ignored ?
    cheers,
    Beau
    I think I am there :
    Connecting signals to assigned pins like IOC[3] appears to work in that, on compiling, the correct chip pin position are displayed on the .bdf diagram.
    However connecting signals to assigned pins like IOC[3] are on a random basis ignored, new pins like IOC3 of arbitrary chip pin position sometimes being assigned, or the pin just being left disconnected, and shown in Ignored Assignments.
    When there is a pin assigned, is possible to then use the Pin Planner to swap them back – unfortunately the diagram then displays the unwanted chip pin positions instead of the correct ones that it was displaying before.
    So it is better to connect signals to un-assigned pins like IOC3; these will be left unassigned, but listed in the pin listing. Using Pin Planner one can then swap them with the correct bracketed pin such as IOC[3], which is then left unconnected. Thus one ends up with the signal connected to the correct chip pin position, and with this displayed correctly on the diagram.
    I have not seen this strange behaviour even on earlier versions of the same circuit, a year or so ago.
    Cheers,
    Beau Webber
