18 years agoThanks Brad and Frank for your quick response.
I am very junior to use VHDL please simplify the solutions for me! :o well, Frank, is that mean I need to add the line that your wrote to my code Vs what I have? Do I need to assign or set wire or reg for that? Here is more part of my code that may help for debugging: (I may drop some stuff from copy and past of the code, but you know what I mean ) Very appreciated for your help and advance. Thanks.-Negar ------------------------- Library and Package Bindings ------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; ------------------------------ Entity Declaration ------------------------------ entity VID_PLD is port ( -- -- Clock(s) -- C_HKSCLK_VID : in std_logic; -- 33MHz Clock should be up & running by now C_VID_SLOW_CLK : in std_logic; -- Note: susclk is availible 100ms + 8 RTC clks -- after NB_RSMRST_N -- Reset(s) -- C_VID_PWROK : in std_logic; -- GCLRn: Pwr_Rst dependent rails stable (min 350 ms) -- -- Other PowerGood / PWROK / Ready / VTT_PWRGD Signals -- C_PVRM_PWROK : in std_logic; G_GFX_VID : in std_logic_vector(7 downto 0); G_VIDOUT : out std_logic_vector(7 downto 0); G_GFX_VIDOUT : out std_logic_vector(7 downto 0); C_MB_OVRR_N :in std_logic; C_RST_VID_S1 : in std_logic; signal VIDOUT : std_logic_vector(7 downto 0); signal VIDOUT1 : std_logic_vector(7 downto 0); signal VIDOUT2 : std_logic_vector(7 downto 0); signal GFX_VIDOUT : std_logic_vector(7 downto 0); --added for GFX VID.--NR signal GFX_VIDOUT1 : std_logic_vector(7 downto 0); signal GFX_VIDOUT2 : std_logic_vector(7 downto 0); MBDTVIDOUT : process (C_RST_VID_S1, C_MB_OVRR_N) begin if (C_RST_VID_S1 ='0') then GFX_VIDOUT <= GFX_VIDOUT1; VIDOUT <= VIDOUT ; elsif (C_MB_OVRR_N ='0') then ---MB mode-->CPU-VID table need to be change VIDOUT <= VIDOUT1(7 downto 0)-"00010010" ; -- ( -12h) VIDOUT <= VIDOUT2 srl 1; --NR:I need to shift 1 bit to right but has syntx error- GFX_VIDOUT <= GFX_VIDOUT1; elsif (C_MB_OVRR_N ='1') then ---DT mode-->GFX Table need to be change VIDOUT <= VIDOUT1; GFX_VIDOUT2 <= GFX_VIDOUT1 sll 1; --NR:I need to shift 1 bit to left but has syntx error GFX_VIDOUT <= GFX_VIDOUT1(7 downto 0)+"00010010"; -- (+ 12h) end if; end process;
