11 years agoHPS power is being analyzed for a device with an HPS without HPS power
Where is HPS Power Calulator Dialog Box in QII web edition?
--- Quote Start --- Where is HPS Power Calulator Dialog Box in QII web edition? --- Quote End --- For anyone else looking for this dialog box, it can be found under "Processing"->"PowerPlay Power Analyzer Tool" option on the main menu bar. This will open up a page where if you scroll down, you'll find a "HPS Calculator..." button. Click this to bring up the HPS option. - Altera_Forum
In Q15 there is HPS Power Calulator Dialog Box in subscription edition but not in Web Edition.. these are my conclusions.. with update 2 maybe this dialog was added to web edition?
Ah, not sure. I just recently started using a school network license with my web edition but haven't had to use powerplay before. The dialog button isn't in the normal settings under Assignments. I'm on 15.0.0 Build 145.
Edit: yep, you are correct. I disabled my license and reopened quartus and the HPS option was gone. - Altera_Forum
--- Quote Start --- For anyone else looking for this dialog box, it can be found under "Processing"->"PowerPlay Power Analyzer Tool" option on the main menu bar. This will open up a page where if you scroll down, you'll find a "HPS Calculator..." button. Click this to bring up the HPS option. --- Quote End --- Thanks for the guide.
