15 years agoAlso be carefull when you run a gate level simulation.
The name of your internal signals can change unless you don't use the 'keep' or 'preserve' attribute. The 'keep' attribute, however, will prevent the optimization of the logic that refer to the 'kept' signal. Hope this helps.
