15 years agoAs rbugalho hinted, you need to "manually" write to the memory module to initialize it... For example, if you want to initialize it to all std_logic '0's, you need to *write* to the memory the value of '0' at every clock cycle.
Altera's devices (and probably other FPGA vendors too) doesn't support asynchronous clearing/resetting of memory contents, probably because it is too expensive to implement on silicon.
