15 years agodclk/sce/data0/sdo pins must be configured "Use as regular I/O" if you want to use them to access epcs after AS configuration.
You didn't specify which device you are using: anyway, assuming a EP3C40, pin K1 is data0, which is probably now set as reserved.
