15 years ago
How to use the $setup() system function in the testbench?
I want to use the $setup() and $hold() system function to check the setup time and hold time in the Verilog testbench,but there is a note show that " unexpected "$setup"" in the Modelsim.
could you help me?
thank you!
1 Reply
    ha ha!I have found the usage of the $setup().
    `timescale 1 ns/ 1 ps
    module diff_notifier(clk,data_A,data_B,data_out,reset);
    input clk;
    input reset;
    input data_A;
    input data_B;
    output data_out;
    specify
     $setup(data_A,posedge clk,1);
     $hold(posedge clk,data_A,0.1);
    endspecify
    endmodule
    module LED_vlg_tst();
    reg eachvec;
    // test vector input registers
    reg clk;
    reg  data_A;
    reg  data_B;
    reg reset;
    reg pha,phb;
    // wires
    wire   data_out;
    wire notifier;
    integer TF;
    integer i;
    // assign statements (if any)
    LED i1 (
    // port map - connection between master ports and signals/registers
     .clk(clk),
     .data_A(data_A),
     .data_B(data_B),
     .data_out(data_out),
     .reset(reset)
    diff_notifier U1(clk,data_A,data_B,data_out,reset);
    initial
    begin
    clk=0;
    TF=$fopen("DATABASE.txt");
    $readmemb("WY.txt",pha);
    $readmemb("KL.txt",phb);
    for(i=0;i<8;i=i+1)
    begin
    # 5;
     data_A=pha;
     data_B=phb;
    # 10;
     $fdisplay(TF,"%b",data_out);
    # 5;
    end
    $fclose(TF);
    $display("Running testbench");
    end
    always# 10 clk=~clk;
    endmodule
