9 years agoHow to use Shared Variable
Tell how you use Shared Variable What you think about Shared Variable What they for
9 years agoSHARED VARIABLES can help you to solve really difficult PSL Assertion problems.
Say you need a Signal or a Sequence Seq1 to Occur Twice in an antecedent & the SECOND Occurrence MUST then be followed by another Sequence Seq2. THEN You DO NOT WANT Another thread to start <<<<<<<<<<< UNTIL After the SECOND Occurrence of Seq1 & then the Occurrence of Seq2. System Verilog's First Match OR PSL's goto repetition ie. [->] Will NOT STOP the UNWANTED thread starting on the SECOND Concurrence of Seq1. Unwanted threads can be avoided. HOW? Create a shared variable that has the following functions (methods). type PSL_BOOL_PType is PROTECTED impure function get( Get_Enable : BOOLEAN ) return BOOLEAN; impure function clr( Clr_Enable : BOOLEAN ) return BOOLEAN; impure function set( Set_Enable : BOOLEAN ) return BOOLEAN; end PROTECTED PSL_BOOL_PType; These all Return the State of the BOOLEAN variable inside the PROTECTED BODY BEFORE the function was called. I'll leave you to write the PROTECTED BODY. Declare Your_Shar_Var shared variable Your_Shar_Var : PSL_BOOL_PType; You can then use Your_Shar_Var to DISABLE the triggering of new threads for your assertion by using Your_Shar_Var.clr(rose(Last)) in the antecedent Where Last is the Last signal to rise in Seq1. You then need another property that includes:- {rose(Last):ended(Seq1)} |-> { Seq2 : (Your_Shar_Var.set(TRUE) or TRUE) -- ORDER of eval Means Your_Shar_Var.set MUST Come 1st } This not only checks for Seq2 but ALSO Re-enables the triggering of new threads. ************ * IMPORTANT ************ PSL has LEFT to Right ORDER of evaluation SO This Means these Functions (Methods) MUST Sometimes Come FIRST ie. on the LEFT of an EXPRESSION OTHERWISE, they May NOT GET CALLED. There is a neater way of doing Seq2 : (Your_Shar_Var.set(TRUE) or TRUE) but it it requires another function. There really should have been a simple built in way of doing this in PSL & SVA BUT As I said above First Match OR goto repetition [->] WILL NOT DO IT. .............................................................. PSL was developed from IBM Sugar SVA syntax is almost the same as PSL BUT JUST TO BE DIFFERENT & INCOMPATIBLE They changed a few things like putting the Clock at the beginning of a property & stuff like# #1 THERE WAS NO EXCUSE FOR THIS. UNFORTUNATELY All 3 Languages use the most APPALLINGLY BAD CRYPTIC SYNTAX BUT We are stuck with it.
