Altera_ForumHonored Contributor16 years agoHow to use Radio Display_Hint in hw.tcl file Hi, In the Quartus II Handbook Version 9.0 there is a nice example of how to create a pull down menu using allowed_ranges add_parameter sound string 0 0 set_parameter_property sound a...Show More
Altera_ForumHonored Contributor16 years agoThanks, I will make a dummy string or stick with the pull down. -Jennifer
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
