11 years ago
How to update PLL frequency in TimeQuest
Hi.
I have source clk 250 MHz and PLL that generates 130 MHz from it. When I changed output PLL frequency to 150 MHz, my design has been faster, but TimeQuest "Report Clocks" reported about old frequency, 130 MHz. How can I update frequency?
And what should I also constrain for PLL?
Thank you.
1 Reply
    OK, I've found the solution:
    1. Change PLL output frequency in Wizard. Remember High and Low parts of M, N, C counters.
    2. Open your SDC file and find PLL VCO and output clocks definitions (create_generated_clock).
    3. Edit VCO clock constraint: Fvco = Fin * M / N, so we should to edit "-multiply_by <M_value> -divide_by <N_value>", where each X_value = X_high + X_low, which we knew from step 1.
    4. Edit output clock constraint: Fout = Fvco / C, so we should to edit "-divide_by <C_value>". C_value = C_high + C_low, of course.
    Maybe exists another method?
