Altera_ForumHonored Contributor16 years agohow to simulation tristate bus in modelsim Could someone let me know if there is a way that I can use a testbench in modelsim to drive a signal into an external tristate bus. I am using vhdl with the bus defined as type inout at the top leve...Show More
Altera_ForumHonored Contributor16 years agoI found a typo that was preventing it from working properly. It does work now.
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorConnection bit order between hierarchyCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
