16 years ago --- Quote Start --- Hi, did you have a look into your generated designfile ? Is the BUSMUX function implemented as blackbox ? Kind regards GPK --- Quote End --- Hi, it is not neccessary to generate a HDL file for the BUSMUX. This is done by the Megawizard itself. All what you have to do is to compile the HDL in Modelsim , but don't forget to include the resource library "220model_ver" (in case you are using Verilog). After doing this all works fine. I have a small project attached. Kind regards GPK
