JSLY
3 years agohow to set up advanced signal tap trigger to do bus comparisson
I am having trouble setting up an advanced signal tap trigger to do a bus comparisson to trigger when RAM read bus = RAM write bus, the tool tells me "Object does not have enough inputs" ??? I...
- 3 years ago
The black dot on left side has to be connected to input. If the input is being deleted or not connected, it'll be highlighted red check screenshot attached. Here is the document reference link for Advanced Trigger Condition https://www.intel.com/content/www/us/en/docs/programmable/683819/22-4/advanced-trigger-conditions.html
Sheng
ShengN_altera
3 years agoHi,
Sheng
