Altera_ForumHonored Contributor14 years agoHow to set_output_delay in this situation? I've two FPGAs working on board. The first fpga has a output data port connected to the 2nd fpga to transmit data. And the sampling clock to sample the data in the 2nd fpga also came from the first f...Show More
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
